Hi! I have created this code, and I assumed that it would change states with a frequency of 100MHz/2^26, but it is instead changing at 100MHz/2^27. I know this is a lack of my basic understanding as I am new to FPGAs, but can someone explain why this is? Thank you!
module au_top (
input clk, // 100MHz clock
input usb_rx, // USB->Serial input
output usb_tx, //
output br_pin[32], //Initialise 32 GPIO pins
output power[8]
sig rst;
dff tmr[26](.clk(clk)); // dff that uses onboard 100MHz clock
values myValues; // call values module outside the clock module - it does not have a clock input
.clk(tmr.q[25]) { // clock is set to 100MHz/2^(25+1)
reset_conditioner reset_cond;
.rst(rst) {
counter myCounter; // call counter module with tmr.q[25] as its clock
tmr.d = tmr.q + 1; // increment counter
reset_cond.in = ~rst_n; // input raw inverted reset signal
rst = reset_cond.out; // conditioned reset
usb_tx = usb_rx; // loop serial port
br_pin = 0; // all GPIO pins initialised to be off
power = myValues.power;
br_pin = myValues.out[myCounter.count];
// all GPIO pins are equal to the eight bit output defined in the values module
// the output generated corresponds to the counter's count
// there is a 100MHz/2^26 pause at each output value
I don’t use Lucid and I am looking at this from a Verilog point of view so this advice is maybe not applicable to Lucid, or maybe it is.
First point of advice:
In Verilog at least, when you declare a register you say:
reg [25:0] reggy = 26’b0;
The register (reggy) is actually 26 bits wide, not 25. The position 0 counts as a bit. This might happen in Lucid, but nevertheless I spotted that you put “dff tmr[26]” and I flinched from experience.
I doubt that this is a problem in Lucid, but, at least in Verilog, the always block you have there should have a sensitivity list like:
always @(some_random_pin_or_register_or_clock) {code}
or
always @(*) {code},
and also the assignments inside should be <= not = if you are using a clocked always block, which it appears you are. Take this advice as a clue where to look, not as a definitive answer, because, like I said earlier, I don’t use Lucid.
@Random_FPGA_Guy thanks for offering some help but most of that isn’t applicable to Lucid.
In Lucid, you simply say how big the array is (no extra 0 index). You also don’t need to worry about sensitivity lists and the <= operator doesn’t exist.
@batmanlover.07 First, you generally shouldn’t use anything for a clock other than the clock signal. This will lead to timing issues at some point and your design will fail in the real world.
tmr.q[25] should be toggling with a frequency of 100MHz/2^26 as you expect. I suspect something in counter is dividing it by 2. You could output tmr.q[25] to br_pin and check it.
The “correct” way to trigger something periodically slower than your main clock is to create a single cycle pulse off the tmr.q[25] signal (say on the rising edge) then use that to do whatever you want. If you explain more what you’re trying to do I can give a full example.
@alchitry Please give a full example if you can!
This is my counter module
module counter (
input clk, // clock
input rst, // reset
output count[3] // count is 3 bits wide as value is three bits wide
.clk(clk), .rst(rst) {
dff val[3]; // maximum val is 5, so val needs to be three bits wide
// if val is two bits wide, it can only have a maximum of 4 (2^2)
if (val.q == 5) // if max value is reached
val.d = 0; // reset to 0
else // otherwise
val.d = val.q + 1; // add one
count = val.q;
Here’s how I would do it.
module alchitry_top (
output led[8], // 8 user controllable LEDs
output usb_tx // USB->Serial output
sig rst // reset signal
.clk(clk) {
.rst(rst) {
counter myCounter
dff tmr[26]
dff lastTmr
reset_cond.in = ~rst_n // input raw inverted reset signal
rst = reset_cond.out // conditioned reset
usb_tx = usb_rx // echo the serial data
tmr.d = tmr.q + 1
lastTmr.d = tmr.q[-1] // MSB
myCounter.pulse = lastTmr.q == 0 && tmr.q[-1] == 1 // rising edge
led = myCounter.count
module counter (
input clk, // clock
input rst, // reset
input pulse,
dff val[3] // maximum val is 5, so val needs to be three bits wide
if (pulse) {
val.d = 0 // reset to 0
else // otherwise
val.d = val.q + 1 // add one
count = val.q
Note that I used -1 to index the MSB. It’s just nice if you ever change the size of tmr then you don’t need to change the index.
I use another dff to store the last value of the MSB then use it to detect rising edges and output a single cycle pulse on that edge. You could also simply check the entire tmr for a value like tmr.q == 0 or &tmr.q (for all 1’s) but doing the rising edge version is likely a little more efficient as it doesn’t depend on the size of tmr.
Thank you so much!
So was what the reason for the extra division in my initial code? Was it due to the counter taking a clock cycle to do its computation, resulting in an output frequency of 100MHz/2^(26+1)?
