Setup with Vivado 2026.1 and Alchitry Au+ Failing build
Machine:
x86 Ubuntu 24.04.5
Software:
Vivado 2026.1, Alchitry Labs 2.0.57
Target:
Alchitry Au+
When I try building a sample project in Alchitry Labs, I see the following logs:
Starting Vivado...
INFO: [Common 17-3922] A valid Vivado Design Suite ALVEO license has been detected. Your current license is active and will expire on 17-oct-2027.
ERROR: [Coretcl 2-106] Specified part could not be found.
****** Vivado v2026.1 (64-bit)
  **** SW Build 6511674 on Tue Jun 16 11:01:26 MDT 2026
  **** IP Build 6504888 on Tue Jun 09 09:05:25 MDT 2026
  **** SharedData Build 6501428 on Mon Jun 08 17:34:18 MDT 2026
  **** Start of session at: Tue Oct 20 16:39:02 2026
    ** Copyright 1986-2022 Xilinx, Inc. All Rights Reserved.
    ** Copyright 2022-2026 Advanced Micro Devices, Inc. All Rights Reserved.
source /home/anand/alchitry/fpga_button/build/project.tcl
# set projDir "./vivado"
# set projName "fpga_button"
# set topName top
# set device xc7a100tftg256-1
# if {[file exists "$projDir"]} { file delete -force "$projDir" }
# create_project $projName "$projDir" -part $device
WARNING: [Device 21-9575] Your current selected license is ALVEO. This license doesn’t cover the device you selected. See the Vivado Licensing page for what devices are supported in each tier and how to get the right license based on your requirements.
INFO: [Common 17-206] Exiting Vivado at Tue Oct 20 16:39:04 2026...
Vivado exited.
Bin file (/home/anand/alchitry/fpga_button/build/vivado/fpga_button.runs/impl_1/alchitry_top.bin) could not be found! The build likely failed.
My license includes ISE_WebPACK, and I’ve installed the Artix-7 tools explicitly.
The simulator in alchitry labs works.
It looks like you don’t have the correct license for Vivado : you have the ALVEO (PCI-express card) license, but what you need is the 7-series basic tier or higher.
Resolved
My license contained both the Alveo and Basic tiers. I unchecled Alveo and regenerated my Xilinx.lic file and it’s working now.
