I tried following the servo tutorial for the Mojo since it didn’t look like there would be any issues using the servo component with the Au, but for the life of me I can’t get it to work!
I’ve included the zip of the project. I’ve tried adjusting all the parameters for the servo component, but I’m pretty sure the values should work since they are what I use in some microcontroller code I know works. I suspect the issue may be with how the BrWide.acf file is declared, but I can’t seem to find anything in the reference that seems like it would be useful beyond the attributes I’ve already set.
Am I missing something obvious? I know the servo works and has power. A multimeter shows a stead 0.445V on pin A6 which I’m using for the servo signal. I would expect the voltage here to vary between 0 and 3.3V, but it’s remained steady no matter what I’ve tried in troubleshooting.
Thanks in advance for any help!
ServoTest.zip (41.8 MB)
