I just went to plug in my Alchitry Pt board, Fan Board and FT board and it suddenly stopped working. I think I may have plugged the Ft USB in first. I heard the fan spin up and saw the green LEDs light up. Then I went to plug in the second USB cable (for the Pt I think) and just as I touched the connector and before I even got the connector plugged in, suddenly the LEDs all went off and the fan stopped.
It will no longer power on.
I think the power supply has failed.
Here’s what I have so far:
I’m looking around U4 part ADP5052ACPZ-R7.
I see VREG at 5V on pin 44.
I see that pin 26,27 (SW2) is driving a switching signal to L2, and the output of L2 is at 1V as expected.
I then see that this should feed pin 48 (EN3), which seems to be working, as I see a switching signal at pin 3 (SW3) driving in to L3. But I don’t see any output at the output of L3. I expect 1.8V.
The signal at SW3 also looks intermittent.
I think I should start by ordering another board ASAP.
Any suggestions on how to debug/repair this?
Any idea what could have gone wrong?
Thanks!
Signal at input of L2:
Signal at input of L3:
Output of L3:
It seems this is ramping up but then stops before it even reaches 1.8V… could this indicate a short in the 1.8V load and a protection behavior by U4?
