Issues with I2C reading eeprom 24AA32A
Hello
I’m having a problem reading back data from the eeprom, the write works fine, and the i2c trace matches the data sheet of the eeprom, but when i read back the data from the eeprom, the read back looks good in the track and there is the data that i stored, but when I get the data, for example test.data_out, the data is missing,
the project is fairly simple, and it is designed for testing, so it is minimual,
there is au_top, eeprom_241132a, and test_eeprom.
so briefly
in test:
if (!usb_tx_busy)
usb_new_tx = 1;
usb_tx_data = test.read_value; // this is the value read from the eeprom first byt
which references:
if(!qwiic.busy) {
state.d = state.RSTOP;
qwiic.write = 0;
qwiic.read = 1;
//read_value = 8b00110011; //qwiic.data_out;
read_value = qwiic.data_out; // <= this is the problem, no data received to read_value
qwiic references the ic2_controller luc code
attached is a trace of the read back
if you have any ideas that would be most appriciated.
regards
Jeff
Here is the trace of the readback
regards
Jeff
here is the code to the three modules
module au_top (
input clk, // 100MHz clock
output led [8], // 8 user controllable LEDs
input usb_rx, // USB->Serial input
output usb_tx, // USB->Serial output
inout sda, // i2c data
output scl // i2c clock
sig rst; // reset signal
.clk(clk) {
reset_conditioner reset_cond;
.rst(rst) {
 eeprom_24AA32A  eeprom(.sda(sda));
 test_eeprom test(.sda(sda));
 // uart_rx uart_rx(#BAUD(9600), #CLK_FREQ(100000000));    //console
  uart_tx uart_tx(#BAUD(9600), #CLK_FREQ(100000000));    //console
reset_cond.in = ~rst_n; // input raw inverted reset signal
rst = reset_cond.out; // conditioned reset
//usb_tx = usb_rx; // echo the serial data
led = 8b11110011;
scl = test.scl;
//test.read_data = 0;
usb_tx = uart_tx.tx;    // connect the output console
// uart_rx.rx = usb_rx; // connect the input console
// usb_tx = usb_rx; // echo the serial data
// USB TX Connections
uart_tx.block    =  0;      // don't block
test.usb_tx_busy =  uart_tx.busy;
uart_tx.new_data =  test.usb_new_tx;
uart_tx.data     =  test.usb_tx_data;
eeprom.cntl_byte_write = 0;
eeprom.cntl_byte_read = 0;
eeprom.high_addr_byte = 0;
eeprom.low_addr_byte = 0;
eeprom.write = 0;
eeprom.read = 0;
eeprom.data_byte = 0;
// USB RX Connections
//test.usb_new_rx  = uart_rx.new_data;
//test.usb_rx_data = uart_rx.data;
test.read_value = 0;
module eeprom_24AA32A
input clk, // clock
input rst, // reset
input write, // write enabled
input read, // read enabled
output busy, // busy indicator 1 = busy
output scl , // i2c clock
input cntl_byte_write[8],
input high_addr_byte[8],
input low_addr_byte[8],
input data_byte[8],
input cntl_byte_read[8],
output read_value[8]
.clk(clk) {
.rst(rst) {
fsm state = {IDLE, START, ARSTART, RSTART, ADDRESS, MEM_ADDR1, MEM_ADDR2, RADDRESS, RRADDRESS, RMEM_ADDR1, RMEM_ADDR2,DATA, READ,RSTOP,WSTOP,SPIN}; // mcp4725 states write
i2c_controller qwiic(.sda(sda)); // i2c controller
// test_eeprom test_access;
dff newvalue[8];
// value to be written to DAC
dff ack_write;
// name eeprom_24AA32A
busy = state.q != state.IDLE;
// i2c signals and connections
qwiic.start = 0;
qwiic.stop = 0;
qwiic.write = 0;
ack_write.d = qwiic.ack_write;
scl = qwiic.scl;
qwiic.read = 0;
qwiic.data_in = 8hxx;
qwiic.ack_read = 0;
newvalue.d = newvalue.q + 0;
ack_write.d = ack_write.q + 0;
read_value = 8b00110111;
qwiic.write = write;
case(state.q) {
  state.IDLE:
qwiic.start = 0;
qwiic.stop = 0;
qwiic.write = 0;
scl = qwiic.scl;
qwiic.read = 0;
qwiic.ack_read = 0;
read_value = 8b00110110;
    // send new dac data
    if(write) {
      // transmit new DAC data over i2c
      state.d = state.START;
      newvalue.d = data_byte;  // capture new DAC data
    if (read) {
      state.d = state.ARSTART;
  state.START:
    // start i2c controller
    if(!qwiic.busy) {
     state.d = state.ADDRESS;
   qwiic.start = 1;
  state.ADDRESS:
    // if not busy write 1st byte, i2c address, write = 0
   if(!qwiic.busy) {
      state.d = state.MEM_ADDR1;
      qwiic.write = 1;
    //  qwiic.data_in = 8b10100000;  // address 0xA0 (<< 1)
        qwiic.data_in = cntl_byte_write;  // address 0xA0 (<< 1)
   state.MEM_ADDR1:
    // if not busy write 2nd byte, low end of byte xxxx0000
    if(!qwiic.busy) {
      state.d = state.MEM_ADDR2;
      qwiic.write = 1;
    //  qwiic.data_in = c{8b00000000};
       qwiic.data_in = high_addr_byte;
  state.MEM_ADDR2:
    // if not busy write 3rd byte, 8 address bits
    if(!qwiic.busy) {
      state.d = state.DATA;
      qwiic.write = 1;
     // qwiic.data_in = 8b00000000;
      qwiic.data_in =  low_addr_byte;
  state.DATA: // write data
   //if not busy write the data byte which is FF
   if(!qwiic.busy) {
     state.d = state.WSTOP;
     qwiic.write = 1;
    // qwiic.data_in = 8b10101010;
     qwiic.data_in = data_byte;
    state.WSTOP:
    // stop i2c controller
    if(!qwiic.busy) {
      state.d = state.SPIN;
      qwiic.stop = 1;
     state.ARSTART:
    if(!qwiic.busy) {
      state.d = state.RADDRESS;
      qwiic.start = 1;
  state.RADDRESS:
    if(!qwiic.busy) {
      state.d = state.RMEM_ADDR1;
      qwiic.write = 1;
  state.RMEM_ADDR1:
    if(!qwiic.busy) {
      state.d = state.RMEM_ADDR2;
      qwiic.write = 1;
  state.RMEM_ADDR2:
    if(!qwiic.busy) {
      state.d = state.RSTART;
      qwiic.write = 1;
    state.RSTART:
    if(!qwiic.busy) {
      state.d = state.RRADDRESS;
      qwiic.start = 1;
    state.RRADDRESS:
    if(!qwiic.busy) {
      state.d = state.READ;
      qwiic.write = 1;
      qwiic.data_in = cntl_byte_read;  // address 0xA0 (<< 1)  // read bit (8) set to 1
    state.READ: // READ DATA BACK
    // if not busy write the data byte which is FF
   if(!qwiic.busy) {
      qwiic.write = 0;
      qwiic.read = 1;
  state.RSTOP:
    if(!qwiic.busy) {
      state.d = state.IDLE;
      qwiic.stop = 1;
    state.SPIN:  // just used for testing
module test_eeprom (
input clk,         // clock
input rst,         // reset
output scl,         // i2c clock
input  usb_tx_busy,
output usb_new_tx,
output usb_tx_data[8],
input read_value[8]
.clk(clk) {
.rst(rst) {
fsm state = {IDLE, START, SPIN};
eeprom_24AA32A test(.sda(sda)); // i2c controller
 dff delay_timer_enter[32];
 dff max_counter[32];
delay_timer_enter.d = 1;
max_counter.d = 1;
//test.usb_tx_busy = 0;
//test.read_value = 0;
test.write = 0;
test.read = 0;
usb_tx = 0;
test.cntl_byte_write = 8b10100000;  // 1010 + 000 + 0  control + address + write mode
test.high_addr_byte  = 8h0;         // xxxx0000  high address
test.low_addr_byte   = 8h0;         // 00000000  low address
test.data_byte       = 8b00110001;  // data to be written which will be a 1
test.cntl_byte_read  = 8b10100001;  // control byte for read
scl = test.scl;
usb_new_tx = 0;
usb_tx_data = 8hxx;
scl = test.scl;
 case (state.q) { // our FSM
  // IDLE: Reset everything and wait for a new byte.
  state.IDLE:
 state.START:
 delay_timer_enter.d = delay_timer_enter.q + 1;
 max_counter.d = max_counter.q + 1;
if (delay_timer_enter.q == 1000000000)  // 1,000,000,000
 //usb_tx_data = 8hxx;
 test.write = 0;
 test.read = 1;
 if (!usb_tx_busy)
 usb_new_tx = 1;
delay_timer_enter.d = 0;
if (max_counter.q == 3000000000)
max_counter.d = 1;
test.read = 0;
test.write = 0;
Ok, fixed, the issue was this:
read_value = qwiic.data_out; needed to be set in the idle fsm, seems to work fine now, regards,jeff
I know I’m responding to a very old post, but if you see this and get a chance, could you please post the final working version of the modules in a preformatted text block? I’m also having some i2c_controller read issues, in my case trying to work with a SparkFun Qwiic OpenLog board (SparkFun Qwiic OpenLog - SparkFun Electronics). Thanks!
If useful to anyone seeing this thread later, my issues were related to the Openlog board requiring the I2C controller to support clock stretching. Justin happened to conveniently add support for this in the controller, and he was very helpful in working with me to debug both sides to make it work in my case. This type of support continues to make Alchitry an enjoyable and gentle introduction into the world of FPGAs for programmers like me.
