Hello, Is there a workaround to use Vivado to burn the Microchip SST26VF032BT-104I/MF flash that is on the Au V2 board. It looks to be command level compatible with Infinion QSPI flash. Is there a way to tell Vivado to ignore the wrong JEDEC ID code and proceed? My Au V2 board came pre-programmed. How was the flash programmed by Alchrity? What is the trick?
I didn’t saw you created a new topic and answered in the other one : here
Thanks, I replied to a really old thread over there but then thought maybe I should start a new one. The answers over there are helpful. We can delete this thread if you like.
