Hi — Gregory Jackson. We are trying the simplest USB3 echo we can: 32-bit 245 FIFO master, SRAM bitstream, D3XX write/read. We expected that to work the same way the Labs Ft Plus V2 Demo does (ui_din = ui_dout). It does not.
Hardware
First: Alchitry Pt first-batch (
PINOUT(PT_ALPHA)), xc7a100, Ft+ on top. -
Then: Alchitry Au xc7a35t + Ft+ (FT601Q, USB
0403:601f). JTAG idcode0x362d093(Artix-7 35T). Published V2au_ft_pluspinout from Without Alchitry Labs / alchitry.github.ioau_ft_plus.xdc. SRAM load only (no flash). -
USB SuperSpeed 5000M.
What we see (16 KiB D3XX, incrementing 32-bit words)
On the Au:
Session endpoint 0x01 times out (
rc=-7). -
After that, D3XX still moves a full 16384 bytes.
words_ok=0,words_bad=4096 -
fail_1:got=0x00000c1a,exp=0 -
fail_2:got=0x00000c1c,exp=1
On the Pt (same kind of test): first word got=0x00000df6 vs exp=0. Bits that are 1 sit in DATA[0:13]; DATA[14:31] are zeros. That first word is not a pin permutation of expected word 0 (any permute of 0 is still 0).
So the host is talking SuperSpeed to an FT601 that will take/return a 16 KiB buffer, but the FPGA is not echoing the payload we sent.
What Alchitry docs actually say (vs 245 vs 600)
We followed public Labs/website material; there is still no host tutorial for Ft/Ft+. Labs 2.0.24: “A tutorial showing how to design an interface and actually get data off is planned.” Starter Serial Interface is the FT2232 UART, not the Ft+.
Shop / boards:
Alchitry Ft: FT600, USB-C mux, ~200 MB/s.
Ft V2 shop: Ft = FT600Q ~200 MB/s; Ft+ = FT601Q 32-bit ~400 MB/s (18 extra IO).
Pinouts Ft+ Bank A: !Wakeup A3, OE A4, !Reset A5, RD A6, WR A9, RXF A10, TXE A12, BE[3:0], D[31:16], CLK on A41 (D17 on A42). Bank B is D[15:0]. Same 245-style names as the Ft (16-bit), just a wider bus.
ACF FREQUENCY: V2 clock-capable pins include A41. Published au_ft_plus.xdc constrains ft_clk as 100 MHz (create_clock -period 10.0, comment 100000000Hz), LVCMOS33.
Lucid Ft Plus V2 Demo (alchitry_top.luc): board clk 100 MHz; ft_clk “Ft 100MHz clock”; ft #BUS_WIDTH(32); ft_wakeup = 1; ft_reset = !rst where rst is only the button through reset_conditioner. After DONE with the button up, ft_reset stays high — they do not pulse RESET_N at config. Echo is ft.ui_din = ft.ui_dout (plus BE). LEDs are {ft_txe, ft_rxf, ui_dout_empty, ui_din_full}, not an ft_clk blink.
[ft.luc]( Alchitry-Labs-V2/src/main/resources/library/components/Interfaces/ft.luc at master · alchitry/Alchitry-Labs-V2 · GitHub ): “BUS_WIDTH: Set to 16 for the Ft (FT600) or 32 for the Ft+ (FT601)”. FSM is clocked on ft_clk. Comments: ft_rxf “low when there is data in the rx buffer”, ft_txe “low when there is space in the tx buffer”, ft_oe “0 = FTDI, 1 = FPGA driving bus”. IDLE until rxf==0 or txe==0; default PRIORITY RX; one-cycle OE then read. That is 245 sync FIFO signaling. The Labs sources never name FIFO “245” vs “600” protocol mode (GPIO/EEPROM). They only distinguish FT600 (16-bit Ft) vs FT601 (32-bit Ft+). There is no official 600-mode example.
We stopped pulsing ft_reset after DONE to match that Lucid policy. Loopback still fails the same way (wrong words, session EP 0x01 -7).
Question
On Au V2 + Ft+, SRAM-loaded bitstream, is a 32-bit 245 echo (Labs Ft Plus demo, or the same OE/RD/WR loopback in Verilog) expected to round-trip D3XX data with the stock FT601 EEPROM? If yes, what host path do you actually use (FT_WritePipeEx pipe 0, chip config, GPIO 00, etc.) and should ft_clk be running at 100 MHz with RESET_N held high after DONE? If 245 loopback is not supposed to work until something else is programmed in the FT601, we would rather hear that than keep adding FPGA state machines.
Happy to post pin/LED notes. Thanks.
