Yes, there is the Hd board for this, it offers 2 micro-HDMI ports that you can set as input or output (out of the box, port 1 is output and port 2 is input)
Oh I didn’t saw this last time I checked, but I found the reason :
HDMI need at least LVDS or TMDS voltages levels that the iCE40 does not offer.
Since the Hd board does not have such transceivers, it have to be built-in the FPGA.
So you’re right, the Hd will not work with the Cu.
You need a board with active conversion such as this, or at least some level shifting trick like this (the trick used by this one is known as AC coupling).
You can search for HDMI boards made for board based on iCE40.
We don’t have any convenient way to send out video on the Cu unless you’re using some LCD that accepts 3.3V parallel data. I don’t think the Cu can switch IO fast enough to drive HDMI without some parallel style adapter.
You could probably hack a VGA connector together and buy a VGA to HDMI or whatever you want. That would be the simplest approach (aside from buying an Au/Pt and Hd).
So the Hd definitely is usable with Cu
At lower resolution than Au and Pt of course (I could run 1080p30 using my Pt, 1080p60 works too but with occasionnal loss of sync), but still perfectly usable.
