Compatibily of Pt first batch with element boards
Hi !
I apologize in advance if my question is already answered elsewhere.
I’m not afraid of tinkering and spending hours reading documentation, so a Pt first batch looks for me like an amazing deal. However, I was wondering if this board was fully compatible with the Ft and the Hd. I don’t mind modifying my vivado constraint files, but if I understand correctly, an extension board using 2.5v or 1.8v is unusable with the Pt first batch.
Thank you in advance
You’re correct that future boards that need 2.5V or 1.8V won’t be compatible with the first batch of Pt.
However, none of our boards currently use the tri-voltage pins. The Hd and Ft work with the Pt just fine on both sides (but you need a spacer (Sp/Br/Fn) for the bottom as the USB/HDMI ports hit capacitors)
