Hello Alchitry Team / Community,
I recently purchased the Alchitry Au V2 and I am planning to build an autonomous robot (SLAM/Computer Vision).
To connect my external hardware, I need a breakout solution. My components are:
2x Servos (HS-65MG+ and PowerHD 1501 MG)
1x TF-Luna Benewake ToF Sensor
I am looking at the Alchitry Br V2. Could you please confirm the following:
Is the Alchitry Br V2 the correct and only compatible breakout board for the Au V2 (Artix 7)?
Does it stack directly on top of the Au V2 using the high-density connectors, or is an additional cable required?
Are there different versions of the Br V2 I should be aware of?
Since I am importing these to Germany and customs duties are quite high, I want to make sure I order the exact matching hardware.
Best regards
