The reason you don’t see anything happening in the interactive simulator is that it is VERY slow compared to the real board (~1000Hz vs 100,000,000Hz). If you modify the loop to take less time it works in the simulation.
module instRom (
input address[8],
output inst[16]
inst = c{Inst.NOP, 12b0}
case (address) {
// begin:
0: inst = c{Inst.SET, 4d2, 8d0} // SET R2, 0
// loop:
1: inst = c{Inst.SET, 4d1, 8d128} // SET R1, 128
2: inst = c{Inst.STORE, 4d2, 4d1, 4d0} // STORE R2, R1, 0
3: inst = c{Inst.SET, 4d1, 8d1} // SET R1, 1
4: inst = c{Inst.ADD, 4d2, 4d2, 4d1} // ADD R2, R2, R1
5: inst = c{Inst.SET, 4d15, 8d1} // SET R15, loop
6: inst = c{Inst.SET, 4d0, 8d7} // SET R0, delay
// delay:
7: inst = c{Inst.SET, 4d11, 8d0} // SET R11, 0
8: inst = c{Inst.SET, 4d12, 8d0} // SET R12, 0
9: inst = c{Inst.SET, 4d13, 8d0} // SET R13, 0
10: inst = c{Inst.SET, 4d1, 8d1} // SET R1, 1
// delay_loop:
11: inst = c{Inst.ADD, 4d11, 4d11, 4d1} // ADD R11, R11, R1
12: inst = c{Inst.BEQ, 4d11, 8d0} // BEQ R11, 0
13: inst = c{Inst.SET, 4d0, 8d11} // SET R0, delay_loop
14: inst = c{Inst.ADD, 4d12, 4d12, 4d1} // ADD R12, R12, R1
15: inst = c{Inst.BEQ, 4d12, 8d0} // BEQ R12, 0
16: inst = c{Inst.SET, 4d0, 8d20} // SET R0, return via inst 20
17: inst = c{Inst.ADD, 4d13, 4d13, 4d1} // ADD R13, R13, R1
18: inst = c{Inst.BEQ, 4d13, 8d0} // BEQ R13, 0
19: inst = c{Inst.SET, 4d0, 8d11} // SET R0, delay_loop
20: inst = c{Inst.SET, 4d1, 8d0} // SET R1, 0
21: inst = c{Inst.ADD, 4d0, 4d15, 4d1} // ADD R0, R15, R1
That being said, there does seem to be something wrong. It won’t build with the open source tools as they fail to meet timing (my run said a max speed of 65MHz) but even with iCEcube2 (which does meet timing) it wasn’t working on my Cu.
I just tested it on my Au and it works so it seems something weird is going on. I’ll take a look and see if I can’t figure out what.
