Mojo V3 Lucid Sdram Test Wrong
Video
I made the shield to test the sdram, I used the same components used to build the original.
Then I ran the SDram test in Lucid and I continue to detect output errors shown by the configuration of the LEDs on the board: LEDs 6: 0 on and 7 flashing.
So I tried to use the example in verilog under ise project navigator and with the latter the test works, 7 LEDs off and one flashing.
There must be some problem with the lucid project but I couldn't identify it.
Can someone try to do the sdram test on mojo V3 with Lucid
to identify the problem?
Thank you
[Image: ynLFrQ0]
I observed differences between the sdram test project compared to the description in the tutorial.
And precisely in the parts:
Code:
// The OODR2 is used to output the FPGA clock to
 // an output pin because a clock can't be directly
 // routed as an output.
 xil_ODDR2 oddr (
   #DDR_ALIGNMENT ("NONE"),
   #INIT (0),
   #SRTYPE ("SYNC")
 // The IODELAY2 is used to delay the clock a bit
 // in order to align the data with the clock edge.
 // These settings assume a 100MHz clock and the
 // SDRAM Shield being stacked next to the Mojo.
 xil_IODELAY2 iodelay (
   #IDELAY_VALUE (0),
   #IDELAY_MODE ("NORMAL"),
   #ODELAY_VALUE (ODELAY_VALUE),
   #IDELAY_TYPE ("FIXED"),
   #DELAY_SRC ("ODATAIN"),
   #DATA_RATE ("DDR")
 and in the parameters passed to these directives.
Code:
// Connections for the IODELAY2
   iodelay.ODATAIN = oddr.Q; // use the ODDR2 output as the source
   iodelay.IDATAIN = 0;
   iodelay.T = 0;
   iodelay.CAL = 0;
   iodelay.IOCLK0 = clk;
   iodelay.IOCLK1 = ~ clk;
   iodelay.CLK = clk;
   iodelay.INC = 0;
   iodelay.CE = 0;
   iodelay.RST = 0;
   // Connections for the ODDR2
   oddr.C0 = clk;
   oddr.C1 = ~ clk;
   oddr.CE = 1;
   oddr.D0 = 0; // using 0 for D0 and 1 for D1 inverts the clock
   oddr.D1 = 1; // because D0 is output on the rising edge of C0
   oddr.R = 0;
   oddr.S = 0;
These are the ones in the tutorial:
Code:
xil_ODDR2 oddr (
 #INIT (0),
 #SRTYPE ("SYNC")
 #IDELAY_VALUE (0),
 #ODELAY_VALUE (100),
 #DATA_RATE ("SDR")
iodelay.T = 0;
iodelay.CAL = 0;
iodelay.IOCLK0 = 0;
iodelay.IOCLK1 = 0;
iodelay.CLK = 0;
iodelay.INC = 0;
iodelay.CE = 0;
iodelay.RST = 0;
oddr.C0 = clk;
oddr.C1 = ~ clk;
oddr.CE = 1;
oddr.R = 0;
oddr.S = 0;
Which are the correct ones?
I built the project with mojo IDE 1.3.6 and the leds behave correctly all off except one flashing.
There is something wrong when compiling build test project in Alchitry.  Big Grin Big Grin Big Grin
