We’re going to be doing labs with these boards remotely next quarter, we’ve arranged for remote Windows systems to do the compilation, but half the students have Macs, so I needed a Mac version of the binary loader.
I was able to pretty easily port the standalone (officially deprecated) command line alchitry-loader for MacOS by doing the following…
From here: https://www.ftdichip.com/Drivers/D2XX.htm
- Download the driver library for 10.4 and later
- Also download and install the “D2XX Helper Tool” (this prevents MacOS from overriding the drivers)
- Follow the instructional video (if you have the helper tool, you don’t have to do the “kextunload” step)
Then do
git clone https://github.com/alchitry/alchitry-loader
cd alchitry-loader/src
c++ -o Alchitry_Loader *.cpp -lftd2xx -lpthread
This will generate a LOT of warnings (>70), but the resulting executable seems to run correctly.
To test it, do
./Alchitry_Loader -l
and it should find the board and return
Devices:
0: Alchitry Au
1: Unknown
Found Au as device 0.
To do a volatile load of a configuration, do
./Alchitry_Loader -r (project).bin
If you want to erase or program the flash, you also need a “bridge” .bin file. You can find “au_loader.bin” and “cu_loader.bin” in this archive:
https://github.com/alchitry/alchitry-loader-gui/blob/master/build/work/alchitry-loader-1.0.0-linux64.tgz
You then erase the flash with
./Alchitry_Loader -p au_loader.bin -e
and program it with
./Alchitry_Loader -p au_loader.bin -f project.bin
To date this has only been tested with an Alchitry Au under MacOS Catalina
