Hello! Loving my AU, but I’ve been having some issues. When I first tried using Alchitry Labs, it wouldn’t get past “Starting Vivado…”
I decided to just learn verilog, and use plain ol Vivado with the loader, which works fine. However, now that I find myself wanting to do more with complex AU features, like the IO module 7-segs and RAM. I dont want to design my own memory controller, and verilog has been pretty confusing - two problems I can solve via Alchitry Labs with lucid. I ported the I/O files into Vivado from Labs for the buttons/DIP row/LED row, which has been enough for my projects until now. I did some investigation through task manager, and it seems that Labs will spawn a Vivado process, which will start eating up one of my processor threads, until after a few minutes, then it will disappear. Upon cancelling the build, Labs reports there is no .bin file found in the destination directory - ‘\working\dir.runs\impl_1\au_top_0.bin) could not be found! The build probably failed.’ I am using Labs 1.2.6, and Vivado 2020.2. I have validated my Vivado files through help → add design tools or devices. I have been troubleshooting with the led to button sample project. Running Windows 10.
Any help would be appreciated.
P.S. I found alchity2.com, and I gotta complement the UI design, except for the miniscule drop-down menus.
Had a similar problem but mine was related to the fact I am running Windows 7 Pro and I fixed it by uninstalling the latest copy of Vivado and going back to the last copy that supported Windows 7 namely Vivado 2019.2 after 2 installs of Vivado 2 hours per install and finally another 2 hours on the Vivado 2019.2.
Alchitry Labs loves it and works beautifully so you can write in Verilog or Lucid I even left a ISE copy of Vivado by installing in a new directory so I can still program the Mojo via Vivado ISE.
The latest version of Vivado will install without a warning that it won’t work on Windows 7 and gives the same error as Tyrving got.
I tried the following hacks as recommended on the Vivado forums and are listed here as it may fix a Windows 10 problem.
ENVIRONMENTAL VARIABLES (WINDOWS SYSTEM VARIABLES) - Windows Control Panel - System - Advanced system settings (from Menu)
DEFAULT
Variable name: NO_XILINX_DATA_LICENSE
Variable value: HIDDEN
MODIFY IT
Variable value: C:.Xilinx\Xilinx.lic <-PLACE YOUR LICENCE PATH HERE Available from License Manager
SOLUTION
Try uninstalling Microsoft redistributable libraries from programs & features and re-installing them.
This error has been seen when the Microsoft redistributable libraries have not been properly installed on the Windows machine.
Re-running the vcredist executables should resolve this issue.
Run both the Visual C++ redistribution executables located at:
32 Bit Installations
\tps\win32\vcredist_x86.exe (e.g., C:\Xilinx\Vivado\2013.2\tps\win32\vcredist_x86.exe)
64 Bit Installations
\tps\win64\vcredist_x64.exe (e.g., C:\Xilinx\Vivado\2013.2\tps\win64\vcredist_x64.exe)
Reboot the operating system.
Just love programming down to the copper with FPGA’s!
Do you have anything unique about your install? I have 1.2.6 and 2020.2 working on Windows 10. Everything is in the default paths on the C drive. I’ve heard of people having issues if it isn’t the C drive.
My Vivado install is in C:\Xilinx\Vivado\2020.2, Labs is in C:\Program Files\Alchitry\Alchitry Labs, installed via the Windows .msi installer. I am happy to provide any other information. School gets out soon, and I will try running all this on a Windows VM to see if it is broken by default. Any way to view the logs of Alchitry Labs for some more verbose error messages?
I’m still at a loss for this. I thought it might have been because you had 2020.3 installed which doesn’t support the Artix 7 family (Au/Au+ fpgas) but you said you have 2020.2.
Yesterday I did a fresh install of Windows 10, Vivado 2020.2, Alchitry Labs, and Java SE 16 (Oracle’s JRE) and had no problems.
Do you have a “work” folder in your Alchitry project after trying to build? Look in there for any logs. There should be a folder “work/vivado/PROJECT_NAME” (where PROJECT_NAME is your project’s name) that has Vivado’s working files.
I was using Java 8 - updating to 16 has resolved the issue entirely. I tried running 1.2.7 prior to java 16, and this did not work either, so I am sure the java version is what resolved the issue, not the Labs update. Thank you for your help! I don’t see any mention of java versions on the Vivado install page - I think telling people to check their java version and update if needed would reduce the prevalence of this issue.
For documentation purposes - The work folder was present, and (upon cross-reference with a successful build) all subfolders were produced, except for the .bin file. The log file just included the starting Vivado, aborted by user, and cannot find .bin file messages.
