Alchitry Lab & Mojo
Hello group,
I just tried to use Alchitry Labs Version 1.1.6 together with my Mojo V3.
I loaded the Mojo Blinker Demo project.
Build went flawless. However programming or erasing did not work.
Error: Could not detect a Mojo.
The Settings menu does not have an entry for setting the COMport.
So, apparently, the IDE does not realize it is about a Mojo.
Even if a Mojo project clearly is selected.
Maybe the Mojo is not supported any more?
P-T
Hey P-T,
This is caused by the change to use libUSB instead of the COM ports. It should automatically detect your board without needing to select a COM port.
To get the proper driver installed see https://alchitry.com/pages/alchitry-labs
You need to make Windows use WinUSB instead.
Justin
