Hi!
I want to program my Alchitry Au+ directly using Xilinx Platform Cable USB II. I hope that this way I will be able to use live on-chip debugging in Xilinx Vivado.
But it doesn't work for me.
I'm using Alchitry Br Prototype Element Board, which has pins for TDI, TDO, TCK and TMS. I connect Xilinx Cable to these four pins. Then I connect GND and +3.3V pins. I'm powering the board by a lab power supply using Raw +5V pin.
The Alchtiry Au+ seems to be alive (a configuration stored in flash runs OK). Status led on Xilinx Cable is green.
But Vivado Hardware Manager says that no board is connected.
(I know that the Xilinx Cable works. It operates without problem with this board.)
What am I doing wrong?
Viktor
20210925_194517 small.jpg (Size: 485.94 KB / Downloads: 20)
Screenshot - 25.09.2021 , 19_51_26.png (Size: 22.82 KB / Downloads: 15)
Screenshot - 25.09.2021 , 20_04_39.png (Size: 166.5 KB / Downloads: 13)
Viktor
