Some confusion about Au DDR3 interface
Hi - I'm trying to work out exactly how this is addressed, and something's wrong with my math.
Starting assumption - it's a 256MB part, and has a 28-bit address field - which is really a 25-bit field since the last 3 are reserved as 0s for ordering.  So there are 2**25 => 33,554,432 distinct addresses.  Which is each address was for an 8-byte block, that multiplies back to 256 MB - but the data in bus is 128-bits / 16 bytes wide?
Do these overlap?  Can I write to address '1' by writing 9 bytes into address '0'?
Alternatively, if it was really a 24-bit address field, with each address being a 16-byte/128-bit block, that would seem like a simpler explanation, if maybe the part interface is shared with a 512MB module and the MSB is unused in the Au's part.
So the data bus is only 16 bits wide but the DDR3 controller always operates in bursts of 8 so you end up with the last three address bits being 0 and reading/writing in 128 bit chunks. This is a design choice of the controller and not a restriction of the DDR3 itself.
This means each of the addresses excluding the last three bits are 16 bytes wide. This gives you 2^24 addresses as you pointed out. The MSB is always 0 since it corresponds to the "bank" which is used when you have multiple DDR3 chips.
