DDR3 memory component questions
Can you please add the DDR3 memory component for the Au+ board in Alchitry Labs ?
In the mean time, can we follow the DDR3 tutorial that was written for the Au board ? Does the tutorial need to be updated with the current software version ? I am using the preview version.
Thanks
The DDR3 component is in Alchitry Labs V1 for both the Au and Au+. Any Au tutorial is applicable to the Au+. The only difference between these boards is the FPGA part number.
It’ll be added to Alchitry Labs V2 when the Vivado IP Core Catalog support is ported (high on the list, but likely behind Verilog support which will be a lot of work).
