Hello guys!
I am planning a project where I need to read an 14-bit ADC with four simultaneously sampled channels at 25 MSPS. The ADC output is LVDS 1.8V, two pairs for each channel.
- I would like to ask you if the ICE40 can handle this amount of data? Is it fast enough?
- Can I connect a board with such ADC using a cable, to the BR board, where I would solder a pin header?
- From the ICE40 application note I understood that the LVDS pairs have to be terminated with 100 ohm resistors. I assume these resistors do not exist on the CU board. Can I solder them on the BR board? Will this be close enough?
I will of course try to use a short cable. - If I use the AU board will I need any soldering of termination resistors or the Artix7 has it built in?
I appreciate any tips to help me decide if using the CU board and in general the ICE40HX FPGA makes sense or I should look for something more powerful.
I have the AU board and I am thinking of buying the CU because it would be a perfect small FPGA companion for the STM32H7 that I plan to use, if only it can work.
Thank you!
