(04-17-2020, 04:51 PM)alchitry Wrote: Hey Mick,
There isn't a specific constraint file for the Br since you will want to define your own pinout. Just use the pin numbers in your .acf file that are on the board (ie A2 for bank A pin 2).
Can you share your code/error messages?
Justin
Hi Justin,
I've developed a really cool project and custom .acf loosely based on your wave project, however this one switches Fibonacci quantities of 21, 34, 55 and 89 PWM outputs using the Au and the Br.
Push buttons with 330 Ohm resistors on B27 and B28 changes the frequency and the waveform and offset respectively. Was interested in possibly going up to 144 using SPI, but still confused with Bank D 23, 24, 27 and 28 as SPI on the Au. Now working on a MOFSET H-bridge signal generator at 4.2kHz with the signal from the FPGA.
BTW those Adafruit 10 pin IDC breakout cables on the Br keep that many GPIO nice and tidy.
Mick
working file: io.acf
pin rpp_pwm[0] B14; // Cable 1 I/O 0
pin rpp_pwm[1] B17; // Cable 1 I/O 1
pin rpp_pwm[2] B15; // Cable 1 I/O 2
pin rpp_pwm[3] B18; // Cable 1 I/O 3
pin rpp_pwm[4] B37; // Cable 1 I/O 4
pin rpp_pwm[5] B34; // Cable 1 I/O 5
pin rpp_pwm[6] B36; // Cable 1 I/O 6
pin rpp_pwm[7] B33; // Cable 1 I/O 7
pin rpp_pwm[8] B8; // Cable 2 I/O 0
pin rpp_pwm[9] B11; // Cable 2 I/O 1
pin rpp_pwm[10] B9; // Cable 2 I/O 2
pin rpp_pwm[11] B12; // Cable 2 I/O 3
pin rpp_pwm[12] B43; // Cable 2 I/O 4
pin rpp_pwm[13] B40; // Cable 2 I/O 5
pin rpp_pwm[14] B42; // Cable 2 I/O 6
pin rpp_pwm[15] B39; // Cable 2 I/O 7
pin rpp_pwm[16] B2; // Cable 3 I/O 0
pin rpp_pwm[17] B5; // Cable 3 I/O 1
pin rpp_pwm[18] B3; // Cable 3 I/O 2
pin rpp_pwm[19] B6; // Cable 3 I/O 3
pin rpp_pwm[20] B49; // Cable 3 I/O 4
pin rpp_pwm[21] B46; // Cable 3 I/O 5
pin rpp_pwm[22] B48; // Cable 3 I/O 6
pin rpp_pwm[23] B45; // Cable 3 I/O 7
pin rpp_pwm[24] A20; // Cable 4 I/O 0
pin rpp_pwm[25] A23; // Cable 4 I/O 1
pin rpp_pwm[26] A21; // Cable 4 I/O 2
pin rpp_pwm[27] A24; // Cable 4 I/O 3
pin rpp_pwm[28] A31; // Cable 4 I/O 4
pin rpp_pwm[29] A28; // Cable 4 I/O 5
pin rpp_pwm[30] A30; // Cable 4 I/O 6
pin rpp_pwm[31] A27; // Cable 4 I/O 7
pin rpp_pwm[32] A14; // Cable 5 I/O 0
pin rpp_pwm[33] A17; // Cable 5 I/O 1
pin rpp_pwm[34] A15; // Cable 5 I/O 2
pin rpp_pwm[35] A18; // Cable 5 I/O 3
pin rpp_pwm[36] A37; // Cable 5 I/O 4
pin rpp_pwm[37] A34; // Cable 5 I/O 5
pin rpp_pwm[38] A36; // Cable 5 I/O 6
pin rpp_pwm[39] A33; // Cable 5 I/O 7
pin rpp_pwm[40] A8; // Cable 6 I/O 0
pin rpp_pwm[41] A11; // Cable 6 I/O 1
pin rpp_pwm[42] A9; // Cable 6 I/O 2
pin rpp_pwm[43] A12; // Cable 6 I/O 3
pin rpp_pwm[44] A43; // Cable 6 I/O 4
pin rpp_pwm[45] A40; // Cable 6 I/O 5
pin rpp_pwm[46] A42; // Cable 6 I/O 6
pin rpp_pwm[47] A39; // Cable 6 I/O 7
pin rpp_pwm[48] A2; // Cable 7 I/O 0
pin rpp_pwm[49] A5; // Cable 7 I/O 1
pin rpp_pwm[50] A3; // Cable 7 I/O 2
pin rpp_pwm[51] A6; // Cable 7 I/O 3
pin rpp_pwm[52] A49; // Cable 7 I/O 4
pin rpp_pwm[53] A46; // Cable 7 I/O 5
pin rpp_pwm[54] A48; // Cable 7 I/O 6
pin rpp_pwm[55] A45; // Cable 7 I/O 0
pin rpp_pwm[56] C46; // Cable 8 I/O 0
pin rpp_pwm[57] C49; // Cable 8 I/O 1
pin rpp_pwm[58] C45; // Cable 8 I/O 2
pin rpp_pwm[59] C48; // Cable 8 I/O 3
pin rpp_pwm[60] C5; // Cable 8 I/O 4
pin rpp_pwm[61] C2; // Cable 8 I/O 5
pin rpp_pwm[62] C6; // Cable 8 I/O 6
pin rpp_pwm[63] C3; // Cable 8 I/O 7
pin rpp_pwm[64] C9; // Cable 9 I/O 0
pin rpp_pwm[65] C12; // Cable 9 I/O 1
pin rpp_pwm[66] C8; // Cable 9 I/O 2
pin rpp_pwm[67] C11; // Cable 9 I/O 3
pin rpp_pwm[68] C42; // Cable 9 I/O 4
pin rpp_pwm[69] C39; // Cable 9 I/O 5
pin rpp_pwm[70] C43; // Cable 9 I/O 6
pin rpp_pwm[71] C40; // Cable 9 I/O 7
pin rpp_pwm[72] C15; // Cable 10 I/O 0
pin rpp_pwm[73] C18; // Cable 10 I/O 1
pin rpp_pwm[74] C14; // Cable 10 I/O 2
pin rpp_pwm[75] C17; // Cable 10 I/O 3
pin rpp_pwm[76] C36; // Cable 10 I/O 4
pin rpp_pwm[77] C33; // Cable 10 I/O 5
pin rpp_pwm[78] C37; // Cable 10 I/O 6
pin rpp_pwm[79] C34; // Cable 10 I/O 7
pin rpp_pwm[80] C21; // Cable 11 I/O 0
pin rpp_pwm[81] C24; // Cable 11 I/O 1
pin rpp_pwm[82] C20; // Cable 11 I/O 2
pin rpp_pwm[83] C23; // Cable 11 I/O 3
pin rpp_pwm[84] C30; // Cable 11 I/O 4
pin rpp_pwm[85] C27; // Cable 11 I/O 5
pin rpp_pwm[86] C31; // Cable 11 I/O 6
pin rpp_pwm[87] C28; // Cable 11 I/O 7
pin rpp_pwm[88] B23; // Cable 12 I/O 0
pin mmr_pwm[0] B20; // Cable 12 I/O 1
pin mmr_pwm[1] B21; // Cable 12 I/O 2
pin mmr_pwm[2] B31; // Cable 12 I/O 3
pin mmr_pwm[3] B30; // Cable 12 I/O 4
pin io_button[0] B28 pulldown;
pin io_button[1] B27 pulldown;
pin io_button[2] B24 pulldown;
excerpt from file: au_top
module au_top(
input clk, // 100Mhz clock
output reg [7:0] led, // 8 user controllable LEDs
input usb_rx, // USB->Serial input
output reg usb_tx, // USB->Serial output
output reg [88:0] rpp_pwm, // RPP Pulse Width Modulation Outputs
output reg [3:0] mmr_pwm, // MMR Wireless Transfer Pulse Width Modulation Outputs
inout [2:0] io_button // 3 push buttons
This program is working fine with the above .acf, but adding SPI on the Au with the Br would be a bonus.
