Lucid to Verilog Counter implementation
Greetings,
I have the transpiled Verilog source of the Lucid Counter component, but the Verilog is using constant values instead of the parameters. Does anyone know what the replacements for the parameters (SIZE, DIV, TOP, UP) would be in the following Verilog source? The biggest confusion I'm having is the use of hex 0x00, because two parameters use that value (DIV and TOP).
Code:
module counter (
   input clk,
   input rst,
   output reg [7:0] value
 parameter SIZE = 4'h8;
 parameter DIV = 1'h0;
 parameter TOP = 1'h0;
 parameter UP = 1'h1;
 reg [7:0] M_ctr_d, M_ctr_q = 1'h0;
 localparam MAX_VALUE = 1'h0;
 always @* begin
   M_ctr_d = M_ctr_q;
   value = M_ctr_q[0+7-:8];
   if (1'h1) begin
     M_ctr_d = M_ctr_q + 1'h1;
     if (1'h0 && M_ctr_q == 1'h0) begin
       M_ctr_d = 1'h0;
     end
   end else begin
     M_ctr_d = M_ctr_q - 1'h1;
       M_ctr_d = 1'h0;
     end
   end
 end
 always @(posedge clk) begin
   if (rst == 1'b1) begin
     M_ctr_q <= 1'h0;
   end else begin
     M_ctr_q <= M_ctr_d;
   end
 end
endmodule
