01-16-2022, 03:58 PM
First, I'm trying to add uarts to serial_port_echo and Alichity Labs doesn't like it. I was able to make the additional pin assignments in Vivado and it worked. Is there a way to run these tutorials in Vivado so I can add to the simulation without errors. For example, when I added uart pins, described them in alchitry.acf, it left 'nulls' in place of the pin assignments in Vivado. After filling them in, Vivado would create a usable bit stream but then I can't modify au_top_plus anymore.
I do not see this board in Xilinx store so I can not get IP's created for it like you can other evaluation boards. Is there a way to construct them with existing files in Alchitry Labs or am I wasting my time? I need 3 extra rs-232 ports combined with DDR to make my project work and I am getting frustrated with trying to use Lucid outside of the demo tutorials.
Any comments would be appreciated.
