CU - IO pin connection
Good day,
Is there any way I can find out which pins on my Cu board are connected to which pin on the Io board? A list or something?
I need this info to be able to work with the io and cu board in icestudio.
With kind regards  Smile
If you want to use it directly in icestudio, you need to make the constraint file from the schematics.
Alternatively, you can fire up Alchitry Labs and create a dummy Io project and have it convert the .acf file into one you can use. I just did this for you and attached the resulting .pcf file for icecube2.
.zip   io.zip (Size: 509 bytes / Downloads: 2)
