Au plus and DDR3 Tutorial
It will not create the Stub file whether I use the above zip or the Au code (same results). I am using Au+. This is the error in Vivado: mig_7series_0_synth_1, Synthesis Out-of-date. Under Chang Log there are 5 errors, netlist.v are and stub.v are two of them. I did fid an article on how to make out of date be ignored but due to upgrades since 2018 I cannot find how to do it.
I saw somewhere that if a Au+ board is used then a stub file is not required.  I cannot get past the Synthesis Out-of-date error.  Anyone know the solution to this?  I am using Vivado 2020.2.
Thank you!
So why am I buying into Alchitry?
The tutorials go so far and then the examples run into problems as they are not being updated, apparently.  I asked what I found out to be a problem with others as well and no support.
I've spent over $200 on this one project and was told that the Au Plus will work the same an Au (just more I/O and capabilities) which was unavailable at the time.  Now I can't get through the DDR3 tutorial because of out-dated software.
It's probably fixable, maybe, I guess if I could get a little push from some talent here!
Thank you,
howdyrichard
Hey howdyrichard,
I really wish I could be of more help, but at this point your best hope is that Justin will solve this next time he checks the forums. The only idea I have is to try install all the software version that were current at the making of the tutorial - but considering as the AU+ was released long after said tutorial was written, I doubt much will come of this.
Best of luck,
Mark
Thanks for at least replying!!! Maybe someone at Xilinx can help...I will look forward to Justin if he cares to undertake the effort.
I don't quite follow where you are getting the error. Is this in Alchitry Labs when you are trying to add the MIG core?
Is it during the MIG core synthesis?
