what is the resolution of the ADC in Alchitry Cu ?
how many bits are used to represent an analog value ?
The XADC is a 12-bit ADC, but it's loaded into an 16-bit data register. The lowest 4 bits are used to add precision if you enable averaging. The XADC is documented in exhaustive detail at https://www.xilinx.com/support/documenta...s_XADC.pdf
(04-09-2019, 06:14 PM)prebys Wrote: The XADC is a 12-bit ADC, but it's loaded into an 16-bit data register.  The lowest 4 bits are used to add precision if you enable averaging.  The XADC is documented in exhaustive detail at https://www.xilinx.com/support/documenta...s_XADC.pdf
is this on alchitry Cu ? oops Cu doesn't have one?
Sorry, my mistake.
Users browsing this thread: 3 Guest(s)
