Good morning. I've dusted off a genuine Mojo v3 I purchased a while back and setoff determined to burn through tutorials this weekend. I've come hat in hand for help as I've exhausted every avenue I know of to troubleshoot programming the board.
My setup:
Windows 10 Pro version 2004 (latest updates) in a Parallels VM running on MacOS Big Sur 11.2.3
Parallels is set to permanently assign the Mojo device within USB settings to my Windows VM.
Windows device manager sees "Mojo V3" under Ports (COM & LPT). It's assigned to COM5 or COM3 depending on the reboot attempt.
Running Alchitry Labs v1.2.5 on the Windows VM. Installed both ways, the .msi and the zip file. Found that the zip file only contained the dpinst-amd64.exe which I ran, confirmed that the driver is installed.
Installed ISE and licensed everything, can build tutorials without any problems.
I'm running JRE 8u281 on the Windows VM.
I also attempted all steps with JDK 16 on the Windows VM before uninstalling that and just trying the JRE.
CMD java -version returns java version "1.8.0_281"
Trouble:
1) When running alchitry-loader, wether I select Erase or Program, the problem completely hangs unresponsive saying "Connecting". I can't grab the window and move it, close it, etc.
2) When running alchitry, following a successful build, an attempt to program lands me at "Connecting" in the status window.
3) Alchitry crashes when I attempt to open the Serial Port or attempt to Register Device.
I read on the forums and github that 1.2.5 was supposed to resolve the Serial Port crashing issue, and question if I have some java issue. I havn't gone so far as to attempt to edit code and debug with print statements. Hopefully someone can set me straight before going scorched earth.
Appreciate any assistance! I'm excited to get my Mojo working.
My setup:
Trouble:
