Clocking with Lattice Parts
Hey,
So with the Mojo, the way to get new clocks was to use coregen via the awesome installed button. Since Cu is a Lattice part there is obviously not a coregen option. Therefore, how do I get my higher or lower clock signal?
(02-22-2019, 06:25 AM)samuelcomeau Wrote: Hey,
If you are using IceCube2 there is a PLL module generator for generating all the PLL code for different clock signals under Tools>Configure>Configure PLL Module although I must admit I havent gotten around to playing with it yet
You can also use the icepll tool of project IceStorm. It generates a Verilog file that contains the PLL module.
Usage example:
Code:
icepll -m -f pll.v -i 100 -o 200
This generates a 200MHz clock from 100MHz input and stores the module into pll.v.
