Java Development Kit Error
On Windows 10 Pro, AdoptOpenJDK 11 installed, new install of Alchitry Labs. If you get a “This application requires at least Java Development Kit 1.8.0 (64-bit)” dialog when starting Alchitry Labs, it may be because you do not have the JavaSoft registry keys installed or correct for your java runtime environment. When I installed the JDK, the installer had an option to do this. It was turned off by default and I did not elect to turn it on.
This registry hack worked for me:
[code]Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft]
[HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development Kit]
“CurrentVersion”=“1.11”
[HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Development Kit\1.11]
“JavaHome”=“C:\Program Files\AdoptOpenJDK\jdk-11.0.9.101-hotspot”[/code]
