Flash Memory Mojo V3
[size=medium]Hello,[/size]
[size=medium]I am building my own mojo V3 card, is it possible to use a SST25VF040B-50 (50Mhz) flash memory instead of the default 80Mhz one?[/size]
[size=medium]Thank you[/size]
Probably shouldn’t make a difference but you may have to tweak the Arduino code https://github.com/embmicro/mojo-arduino
I took a look at the firmware source files and believe I am able to update the source to use the 50MHz flash memory.
I have checked and there is a substantial price difference from the 50MHz to the 80MHz version found on the mojov3 about 10 times as much when compared with non-microchip chips.
Thanks,
PS: I’m having fun using fpga, I had never used them.
:smiley:
