Cu Demo Project fails to build with IceStorm
Using Alchitry Labs 1.0.3 on Linux using the ubuntu-provided IceStorm packages (fpga-icestorm et al).
I had the IDE create a new Lucid "Cu IO Element Demo" project and built it.
It fails with:
Code:
Finished synthesis.
Project IceStorm doesn't support .sdc constraints. "/home/.../CuDemo/work/constraint/alchitry.sdc" will be ignored.
seed: 1
device: 8k
read_chipdb +/share/arachne-pnr/chipdb-8k.bin...
 supported packages: cb132, cb132:4k, cm121, cm121:4k, cm225, cm225:4k, cm81, cm81:4k, ct256, tq144:4k
read_blif /home/.../CuDemo/work/alchitry.blif...
prune...
read_pcf /home/.../CuDemo/work/constraint/alchitry.pcf...
instantiate_io...
fatal error: $_TBUF_ gate must drive top-level output or inout port
Finished placement.
Error: Failed to open input file.
Bin file (/home/.../CuDemo/work/alchitry.bin) could not be found! The build probably failed.
Did you check if all inputs and outputs are assigned correctly?
"fatal error: $_TBUF_ gate must drive top-level output or inout port"
sounds like your .blif file wants to drive something the wrong way.
This is the default project shipped with the alchitry-labs IDE, so I would have expected it to work unchanged.
Maybe this is the issue: https://github.com/YosysHQ/arachne-pnr/issues/112
What version of yosys and arachne-pnr are installed?
Sadly I cannot test as I don't know how to pass lucid to yosys (Alchitry-Labs does not run on my machine). If you have the converted Verilog (*.v) I could test with my version.
Ubuntu 18.04
fpga-icestorm 0~20160913git266e758-3
fpga-icestorm-chipdb 0~20160913git266e758-3
yosys 0.7-2  (changelog.Debian shows last update on 2016-Nov-06)
arachne-pnr 0.1+20160813git52e69ed-1
arachne-pnr-chipdb 0.1+20160813git52e69ed-1
Code:
$ yosys -V
Yosys 0.7 (git sha1 61f6811, gcc 6.2.0-11ubuntu1 -O2 -fdebug-prefix-map=/build/yosys-OIL3SR/yosys-0.7=. -fstack-protector-strong -fPIC -Os)
$ arachne-pnr -v
arachne-pnr 0.1+20151224git1a4fdf9 (git sha1 1a4fdf9, g++ 6.2.0-10ubuntu1 -O2 -fdebug-prefix-map=/build/arachne-pnr-8ETCVz/arachne-pnr-0.1+20160813git52e69ed=. -fPIE -fstack-protector-strong)
Attached the alchitry-labs generated "work" directory:
.tar   CuDemo_work.tar (Size: 120 KB / Downloads: 15)
#6
I tried with different newer versions of yosys and arachne-pnr.
The result is the same:
Quote:alchitry.blif:1781: fatal error: toplevel inout port 'io_dip[0]' connected to tristate buffer and driving a net
On the 35C3 congress I heard that arachne-pnr is superseded by nextpnr so I tried to build with it. And it seems to be successful. I did not had the time to test. But there is an bitstream (see attachment (named .txt as else not accepted)).
What I did to build (In the work directory):
Code:
yosys -p 'synth_ice40 -top cu_top_0 -json alchitry.json' verilog/*.v
cat constraint/*.pcf > all.pcf
nextpnr-ice40 --hx8k --package cb132 --json alchitry.json  --pcf all.pcf  --asc alchitry.asc
icepack alchitry.asc alchitry.bin
The toolchain I had to compile by hand:
https://github.com/YosysHQ/nextpnr
https://github.com/cliffordwolf/icestorm
https://github.com/YosysHQ/yosys
Sadly this is not a comfortable way for unexperienced users. As this toolchain is very new you have to expect some issues.
I will try the bitstream later (I hope there is something to see without the shield).
- RRC
.txt   alchitry.txt (Size: 131.93 KB / Downloads: 13)
#7
As far as I can test with just the basic Cu board it worked. It wasn't anything on the LEDs but the programmed loop of the serial bus responded.
I tested that with python:
Code:
>>> from pylibftdi import Device;
>>> device = Device(interface_select=2)
>>> device.flush()
>>> device.flush()
>>> device.write("a")
1
>>> device.read(1)
'a'
#8
The IO example doesn't build for me under IceStorm either although I get a different error during synthesis. I haven't had a chance to figure out what's going on.
It does build and work under IceCube.
