Cannot build the Cu base project - Printable Version +- Alchitry Forums (https://forum.alchitry.com) +-- Forum: Alchitry (https://forum.alchitry.com/forum-1.html) +--- Forum: General Questions (https://forum.alchitry.com/forum-2.html) +--- Thread: Cannot build the Cu base project (/thread-454.html) |
Cannot build the Cu base project - citizen34 - 08-15-2022 Hi, I'm trying out my new Cu dev board on a Windows 10 machine. However, having followed all the installation setup instructions, when trying to build the base project with the LED & reset button I get the following output (not more not less) : Starting iceCube2... Bin file (D:\ALCHITRY_Projects\TEST\test2\work\alchitry_imp\sbt\outputs\bitmap\cu_top_0_bitmap.bin) could not be found! The build probably failed. I have noticed this error is recurrent amongst other users on this forum and I have tried a few of the proposed fix-arounds to no avail. I am using Java version 8 Update 341 (build 1.8.0_341-b10) and my virus protection has been temporarily turned off during the tests ... Is there a fix for this or otherwise a previous working version of the IDE as I'm using the most recent version 1.2.7. Looking forward to your advice. cheers, Michael |
