Connecting multiple FPGAs? - Printable Version +- Alchitry Forums (https://forum.alchitry.com) +-- Forum: Alchitry (https://forum.alchitry.com/forum-1.html) +--- Forum: General Questions (https://forum.alchitry.com/forum-2.html) +--- Thread: Connecting multiple FPGAs? (/thread-382.html) |
Connecting multiple FPGAs? - stefanwebb - 12-14-2021 Hi There, I'm new to FPGAs and wanted to ask what may be a naive question: Is it possible to connect multiple Alchitry Au boards via the IO pins? I.e. can you connect the output pins from a first board to input pins in a second and use the digital signal generated from the first board to drive the second one? I am interested in combining several FPGAs to build more complex logicĀ and scaleĀ up my prototypes RE: Connecting multiple FPGAs? - Tyrving - 12-29-2021 Not an expert, but I see no reason why this would not work. Your bandwidth would be limited by the frequency of i/o writes and number of i/o pins you use - in the gigabit/sec range, but still lower than something you could achieve within a single fpga fabric. Reliability and lack of shielding using extraneous wires might be an issue at high frequencies, but also might work fine. Buying a bigger FPGA, using external (non-fpga) ICs for simple tasks might give you more LUTs to play with. What type of project are you working on? Hope this helps, Mark RE: Connecting multiple FPGAs? - alchitry - 01-11-2022 You can definitely do this but the biggest issue you can run into is timing. If the two FPGAs are running off different clocks, your signals will inevitably get out to sync. If you run them both off the same clock (it's possible but kinda tricky to output the clock to another pin) you can still run into issues depending on how long the lines are. If you just want to use something simple like UART or SPI to talk from one to the other that's pretty easy. If it's possible, it is usually better to go with a bigger FPGA. Then the tools take care of all the internal timing for you. |
