Mojo V3 not connecting - Printable Version +- Alchitry Forums (https://forum.alchitry.com) +-- Forum: Alchitry (https://forum.alchitry.com/forum-1.html) +--- Forum: General Questions (https://forum.alchitry.com/forum-2.html) +--- Thread: Mojo V3 not connecting (/thread-312.html) |
Mojo V3 not connecting - andreipit - 03-04-2021 I recently bought a Mojo V3, but after i write the code in Alchitry Labs, build it succesfully and then press Program nothing happens, it just says Connecting. Any1 who can help me with this problem? RE: Mojo V3 not connecting - alchitry - 05-18-2021 Can you confirm you have a real Mojo? If you recently bought it (in the last threeish years) we didn't make it. Some of these work, some of them don't. RE: Mojo V3 not connecting - tistructor - 05-21-2021 Try using Mojo Loader, it should work. Alchitry-Labs under windows 10 in my case fails to detect the com port correctly. Only in some cases removing and replacing the serial drivers did it work but if I remove the usb connector and put it back, the com port is no longer detected. A manual port setting system like in Mojo-Loader or IDE would be better. My Mojo is not original. No problem under linux. ![]() RE: Mojo V3 not connecting - alchitry - 06-09-2021 I just pushed 1.2.7 which should fix this. |
