Error when Debugging with Alchitry Labs 1.2.5 - Printable Version
+--- Thread: Error when Debugging with Alchitry Labs 1.2.5 (/thread-298.html)
Error when Debugging with Alchitry Labs 1.2.5 - Jay8ee - 01-12-2021
Hi.
When I click debug > choose the signals I want in the wave capture, I get the following error:
Code:
java.lang.NullPointerException: Cannot invoke "com.alchitry.labs.parsers.lucid.parser.LucidParser$NameContext.getText()" because the return value of "com.alchitry.labs.parsers.lucid.parser.LucidParser$Output_decContext.name()" is null
    at com.alchitry.labs.parsers.tools.lucid.toVerilog.LucidToVerilog.exitOutput_dec(LucidToVerilog.java:477)
    at com.alchitry.labs.parsers.lucid.parser.LucidParser$Output_decContext.exitRule(LucidParser.java:767)
    at com.alchitry.labs.tools.ParseTreeMultiWalker.exitRule(ParseTreeMultiWalker.java:49)
    at com.alchitry.labs.tools.ParseTreeMultiWalker.walk(ParseTreeMultiWalker.java:31)
    at com.alchitry.labs.tools.ParseTreeMultiWalker.walk(ParseTreeMultiWalker.java:29)
    at com.alchitry.labs.tools.ParserCache.walk(ParserCache.java:127)
    at com.alchitry.labs.parsers.tools.lucid.toVerilog.LucidToVerilog.convert(LucidToVerilog.java:50)
    at com.alchitry.labs.project.builders.ProjectBuilder.getVerilogFile(ProjectBuilder.java:187)
    at com.alchitry.labs.project.builders.ProjectBuilder.getVerilogFiles(ProjectBuilder.java:341)
    at com.alchitry.labs.project.builders.VivadoBuilder.generateProjectFile(VivadoBuilder.java:120)
    at com.alchitry.labs.project.builders.VivadoBuilder.projectBuilder(VivadoBuilder.java:33)
    at com.alchitry.labs.project.builders.ProjectBuilder.build(ProjectBuilder.java:152)
    at com.alchitry.labs.project.Project$build$1.invokeSuspend(Project.kt:1260)
    at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
    at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:56)
    at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
    at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:738)
    at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
    at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
Please note that my project builds fine normally. It is basically a blank base AU project (Verilog).
Any ideas?
Thanks.
RE: Error when Debugging with Alchitry Labs 1.2.5 - alchitry - 01-14-2021
The debug button should be hidden for Verilog projects. The code that modifies your design only can modify Lucid modules.
RE: Error when Debugging with Alchitry Labs 1.2.5 - Jay8ee - 01-14-2021
(01-14-2021, 03:09 PM)alchitry Wrote: The debug button should be hidden for Verilog projects. The code that modifies your design only can modify Lucid modules.
oooohhh. That makes sense. Will try that.
Thanks.
