Core naming bug - Alchitry Labs V1.16 - Printable Version
+--- Forum: Tips and Tricks (https://forum.alchitry.com/forum-3.html)
+--- Thread: Core naming bug - Alchitry Labs V1.16 (/thread-164.html)
Core naming bug - Alchitry Labs V1.16 - IvanLentil - 03-29-2020
Hi all,
this bug applies in Mojo projects with Xilinx ISE. I haven't checked if it affects with Vivado.
If you use Coregen to build a core, Alchitry Labs uses the default name for the core even if you use a different name when generating it. This can be a problem if you use more than one variant of the same basic core - for example if you use more than one configuration of block ram.
A simple workaround is to exit Alchitry Labs and manually edit the project file to change the core details.
HTH
